CA Single Sign-On supports encrypted connections using DIGEST-MD5 or GSSAPI. When you use an encrypted connection to the directory server, you do not have to use a service account to bind to the LDAP server (the UserBind parameter that you set in the Single Sign-On Configuration Tool).
To use GSSAPI for encryption, you must change some settings in a configuration file.
Log in as root or with the 'sudo' command.
Installation Dir/webapps/sso/Configuration/
[libdefaults]
default_realm = CA.COM
[realms]
CA.COM = {
kdc = EXAMPLE.CA.COM
default_domain = CA.COM
[domain_realm]
.CA.COM = CA.COM
where:
Contains default values for the Kerberos V5 library.
Maps subdomains and domain names to Kerberos realm names. Lets programs determine the realm for a host, based on its fully qualified domain name. In this example, the default realm is CA.COM.
Contains information about Kerberos realm names, which describe the location of Kerberos servers and include other realm-specific information.
Is the Kerberos key distribution center to support authentication services. For example, EXAMPLE.CA.COM.
Is the default IP domain. For example, CA.COM.
Note: Your Active Directory or LDAP Administrator can probably provide you with a krb5.conf file or help you to create one.
