The Single Sign-On component provides the login page that supports user authentication in CA Performance Center and in the data source products. Single Sign-On supports the following authentication methods:
The CA Performance Center administrator can modify settings for an individual instance of Single Sign-On. For example, you can set up LDAP authentication in Single Sign-On. You can also configure optional encryption with Secure Sockets Layer (SSL) or change the default virtual directory.
Note: As a result of the distributed architecture, any updates to the Single Sign-On website only affect those data source products that are running on the same server.
