Before you can configure the Single Sign-On website to use HTTPS, you must obtain and install a private key and an associated public certificate. SSL can be used with either a self-signed certificate or a certificate that a trusted Certificate Authority has signed. The procedures are typically specific to an organization and the policies of its security team. However, these procedures provide some information to guide you.
Select the appropriate procedure for your situation:
Note: For more information about the keytool command that is used in these procedures, see the Java documentation on the Oracle website.
