The Single Sign-On Configuration Tool lets you test the LDAP settings that you have supplied. You can verify that LDAP authentication is set up correctly. An LDAP test script prompts you to specify a username and password combination to test, using the current settings for LDAP authentication. If you have not already used the Configuration Tool to change LDAP authentication settings, the defaults are used.
Log in as root or with the 'sudo' command.
InstallationDirectory/CA/PerformanceCenter
You are prompted to select an option. The available options correspond to CA applications running on the local server.
The prompt asks you to enter a username.
Single Sign-On attempts to use the parameters you supplied when you set up LDAP authentication to connect to the LDAP server and validate the user account. If the test succeeds, numerous steps are logged.
A message reports whether the authentication succeeded or failed.
