Valid on Console
If you attempt to launch the installation or upgrade program on a server that has NetQoS Performance Center installed, an error message opens, and the installation is canceled.
CA Network Flow Analysis cannot be installed on the same server as CA NetQoS Performance Center. NPC must be completely removed before you proceed with the CA Network Flow Analysis installation or upgrade.
