You have the option to disable services that are not needed by the product. This step is designed to help secure your servers. This step is not required. If the following services are needed for another reason, do not disable them.
If you want to disable unneeded services on the Windows servers in your deployment, use the steps in this topic.
Required/Optional |
Servers to Configure |
Optional |
Any servers (Windows) |
The Services window opens.
Do not select Stop or the services will restart whenever the server is rebooted.
Windows Server Services That You Can Disable |
