We recommend that you create an empty TrapConfiguration key in the Windows Registry to prevent the SNMP service from logging false positive events. This topic describes how to perform this step.
Required/Optional |
Servers to Configure |
Recommended |
All servers |
reg add HKLM\SYSTEM\CurrentControlSet\Services\SNMP\Parameters\TrapConfiguration
If the command executes successfully, the return value is: "The operation completed successfully."
The TrapConfiguration registry key is created in the following location: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SNMP\Parameters.
