Previous Topic: Language SupportNext Topic: New Features and Enhancements
Flow Support
The current version of CA Network Flow Analysis supports NetFlow versions 5, 7, and 9 and the following flow types, provided that they conform to the standards for NetFlow v5, v7, or v9:
In order for data from non-sampled flows to appear in reports of 15-minute (historical) data, the following minimum fields are required:
Note: NetFlow provides a broad view of your network packet streams by creating flow records for all packets. The data from these flow records represents all packets. Sampled NetFlow/IPFIX and sFlow take samples from your packet streams, producing fewer flow records and lessening the impact to a collector. The lower your sampling rate, the less precise the data is likely to be.
