Previous Topic: Deployment OptionsNext Topic: Windows System Requirements and Recommendations
Software Versions that Are Supported for Upgrade
CA Network Flow Analysis 9.3.0 supports upgrades from the following versions to the current configuration:
From
Upgrade To
NFA 9.2.1 operating with
CA PC 2.3.x
NFA 9.3.0 operating with
CA PC 2.4/2.3
NPC 6.1.205 SP2
NPC 6.1.205 SP2
When you upgrade the software, you continue to use the same architecture you used for release 9.2.1, as shown in the following list:
CA Network Flow Analysis 9.2.1 is the only software version that you can upgrade directly to release 9.3.0. If you have an earlier version, upgrade to version 9.2.1 before you proceed. For more information, see the CA Network Flow Analysis 9.2.1 Upgrade Guide.
Notes:
