Previous Topic: Windows System Requirements and RecommendationsNext Topic: Language Support
Linux System Requirements and Recommendations
If you install the Harvester software on a Linux system, verify that your hardware meets the recommendations and requirements that are noted here, in the CA Network Flow Analysis Installation Guide, and in the CA Network Flow Analysis Upgrade Guide. For the latest version of the documentation, visit CA Support.
Setting or Component
Description
Operating System
Red Hat Enterprise Linux 5.5 or 5.6 on a 64-bit processor
Language
English, Chinese (Simplified), French (France), or Japanese language
The appropriate language packs are required for localized deployments.
Disk Space
Root partition that contains 40 GB of available space
Partition for CA Network Flow Analysis that contains the following amounts of available space:
  • 41 GB for the installation files
  • 1 TB for data
CPU
Two 2.26-GHz quad core processors
Memory
12 GB RAM
Hard drives
Six 300-GB, 10,000-RPM SAS hard drives in RAID5 configuration
If you do not have enough available space in the /tmp directory and you cannot configure it, relocate the directory. Export the IATEMPDIR environment variable (for the Install Anywhere temporary directory) to set a new location, and select a directory with sufficient available space.
Ports
1-Gb Ethernet port
Screen resolution
Minimum display resolution of 1024x768 (XGA)
Features, settings, and additional software
  • Java Runtime Engine (JRE) 1.6u45, which is installed automatically during the installation or upgrade of the CA Network Flow Analysis software.
  • System configured as described in the Installation Guide and Upgrade Guide
