Previous Topic: Delete Saved Report DefinitionsNext Topic: Flow Forensics Reports
Delete Report Folders
You can delete unneeded report folders and their contents. Be sure that you do not delete useful report definitions or folders. Deleted folders and report definitions cannot be restored.
  1. In the Saved Report Folders pane, select the check box next to all the report folders that you want to delete.
  2. Click Delete.
    A confirmation box opens. If the folders contain report definitions, the confirmation box reminds you of the number of report definitions that will be deleted.
  3. In the confirmation dialog box, click OK.
    The confirmation box closes. The list of saved report definitions is updated.
