Previous Topic: Interface: Stacked Trend ChartsNext Topic: Stacked ToS Trend
Stacked Protocol Trend
The Stacked Protocol Trend views in the Performance Center Console show the protocols that are used the most heavily for traffic on the selected interface. The views also show when the traffic occurred.
The example graphic shows a Stacked Protocol Trend view in the CA Performance Center Console. A timeline of rates is included for each listed ToS value. You can configure the view to display rate, utilization, or volume information.
Stacked Protocol Trend views show the type of traffic consumed on an interface and the time of consumption.
The views include the following information:
Identifier
Identifies the interface that is used for the report. The identifier string consists of the router name, interface name, and interface description (under the view title).
(NPC) The identifier line also includes the interface speed.
Protocol Bands
Show the data rate, the data volume, or the interface capacity utilization for each top protocol that is associated with traffic on the interface.
Time (All Views)
Point in time during data transmission--expressed in hours and minutes (X-Axis).
Measurement Setting:
Depending on the data direction, the view shows inbound, outbound, or total data on the interface.
Legend
Identifies the protocol for each color band by protocol keyword and tcp/udp port (bottom of the view).
Performance Center views show the data from the time range that is defined for the page.
Opening the Views
To see these views in the Performance Center Console, go to one of the following locations:
Note: You can add Multi-Interface Stacked Protocol Trend views to a custom dashboard or to a custom tab in the Interface pages in the CA NetQoS Performance Center Console. This view consists of a group of interface-specific stacked protocol trend charts
Available Actions
You can perform several actions in this view, including the following ones:
Find Protocol Trend Data in the NFA Console
You can display protocol volume in the NFA console in trend charts or stacked trend charts for a selected interface:
To display Flow Forensics-level detail, click the Flow Forensics link and run a Flow Forensics report.
