Each dashboard and Interface page contains options to export and send data in reports.
You can send a report by email immediately, or you can create a schedule for recurring emailed reports. For example, you can email interface utilization reports each week to coworkers in the IT department for capacity planning.
Note: The administrator must specify an email server to enable this feature. In CA Performance Center, your user account must have the 'Send Reports by Email' role.
The Email Dashboard dialog opens.
Specifies the email addresses where the report should be sent. Use the standard format:
<name>@<domain>
Appears in the email Subject line; describes the emailed report.
Example: The dashboard title and any components whose data is included in the report.
(Optional) Is a message to accompany the emailed report.
Sends the email message immediately. Scheduling is not enabled.
Sends the email message once or more per day. If you select this option, select the day or days of the week when the report is sent.
Default: Send the emailed report every weekday (Monday - Friday) at 0:30 hours in the time zone of the logged-in user. The data in the report reflects the previous 24 hours.
Sends the email message once per week. If enabled, lets you select the day of the week to send the report.
By default, the weekly schedule sends the emailed report every Sunday at 01:00 in your time zone.
Default: The data in the report reflects the previous seven days (Saturday - Sunday).
Determines the day when the week ends. The start of the week is automatically adjusted to include seven days.
Sends the email message once per month. The report is sent on the first Sunday of each month at 01:00 in the time zone of the Management Console. The data in the report reflects the previous 30 days.
Determines the time of day when the message is sent. The start of the month is automatically adjusted to include 30 days.
Sends the email message once per quarter. The report is sent on the first Sunday of each quarter at 01:00 in the time zone of the Performance Center Console. The data in the report reflects the previous three months.
Determines the month when the quarter ends. The start of the quarter is automatically adjusted to include three months. All other quarters are also adjusted to proceed from the first quarter.
Sends the email message once per calendar year. Sends the report on the last day of the month you select for the 'Year ends in' parameter. The data in the report reflects the previous 12 months.
Determines the month when the year ends. The start of the year is automatically adjusted to include 365 days.
Sends the email message at a time you select.
The report is saved as a PDF file and attached to an email message. It is sent immediately or according to the schedule you selected.
