Maintenance and Data Collection › How to Back Up and Restore Data › Databases to Back Up
CA Network Flow Analysis uses several databases to store configuration data, 15-minute (historical) data, high resolution (1-minute) data, and Enterprise Overview data. This topic describes databases to consider for backups and gives general recommendations for backup frequency. Data is used differently in different environments, however, so your priorities for safeguarding against data loss may vary.
All Servers
- Customized configuration files: Back up any other customized configuration files--files that you customized or that were customized by CA Support.
Location: Files with an .config, .conf, or .ini extension that are located anywhere in the CA Network Flow Analysis installation path
Recommendation: Daily backup
Single Sign-On Program
(CA PC deployments) Back up any customized Single Sign-On configuration settings on the SSO server, which may be the Performance Center server. If you lose customized Single Sign-On settings, you may not be able to log in.
- Single Sign-On (SSO) configuration files, as described in the "Back Up Single Sign-On Configuration Files" topic of the CA Performance Center Installation Guide.
NFA Console (Distributed Deployment)
Harvester (Distributed Deployment)
- Historical (15-minute) data (ReaperArchive15 database on a two-tier distributed deployment): The contents of this database include the 15-minute data that is stored for the reporting routers and interfaces.
Location: <install_path>\Netflow\datafiles\ReaperArchive15
Recommendation: Weekly backup
- Harvester and poller configuration files: The poller and harvester configuration data are essential to perform the relational mapping that provides access to the 15-minute data. The poller configuration data provides information about devices and interfaces to enable polling, such as persistent IDs for interfaces.
Locations: <install_path>\MySql\data\harvester and <install_path>\MySql\data\poller
- (Optional) Flow Forensics data (HarvesterArchive database):
Location: <install_path>\Netflow\datafiles\HarvesterArchive
Many administrators do not back up Flow Forensics data because of its short storage life--a maximum of 24 hours.
- (Optional) High-resolution (1-minute) data files (ReaperArchive database): Many administrators do not back up 1-minute data because its high volume requires long backups. When you decide whether to back up these files, consider these factors:
- Value that this single day of data has in your particular circumstances
- Long back up time
The 1-minute data is stored for one month.
- Customized Data Retention configuration files: If you have customized any data retention settings, back up the data retention configuration data.
Note: It is unusual to customize data retention settings, except with the assistance of CA Support. Changes to data retention settings can cause problems as the demands on drive space rise.
DSA (Three-Tier Distributed Deployment)
- Historical (15-minute) data (ReaperArchive15 database on a three-tier distributed deployment): The contents of this database include the 15-minute data that is stored for the reporting routers and interfaces.
- Historical (15-minute) data (MySQL nqrptr database): This directory contains the DSA settings.
Stand-Alone Server
- Reporter database: The contents of this database include the previous 24 hours of Enterprise Overview data, settings, and synchronization information.
- Historical (15-minute) data (ReaperArchive15 database): The contents of this database include the 15-minute data that is stored for the reporting routers and interfaces.
Many administrators do not back up Flow Forensics data because of its short storage life--a maximum of 24 hours by default.
- Long back up time
The 1-minute data is stored for one month by default.
