Previous Topic: View Options in CA NetQoS Performance CenterNext Topic: Set a Custom Time Frame
Change the Context for a View
You can change the context for some individual views on a dashboard. Change the context of an enterprise-wide view to show data from a different set of managed items. Change the context of an interface-specific view in the CA Performance Center Console to show data from a different interface.
Changing the view context can be useful for troubleshooting. You can compare data from different locations, for example.
  1. Open the dashboard that contains the view that you want to change.
  2. (Optional) Change the time frame, if necessary.
  3. Open the dialog for editing the view settings:
  4. Take one of the following steps:
    The context types that are available depend on the type of view.
  5. (Optional) Change the view Title to reflect the new context.
  6. Select the scope of your changes from the Apply Changes drop-down. Select one of the following options:
    Note: The availability of these options depends on your user account role rights.
  7. Click Save (CA PC) or OK (NPC).
    The view is updated to show data from the new context.
You can also change the context for a custom dashboard, which applies the selected group or managed item as a filter to all views on the page.
