Add and delete Harvesters on the Harvester page.
To add a Harvester, complete the steps in the topic Add a Harvester.
To delete a Harvester, complete the steps in this topic.
Note: If you delete a Harvester you cannot add the same Harvester instance again successfully unless the installation server has been re-imaged and the Harvester software has been re-installed. Once you delete a Harvester, you cannot recover any of the data that the Harvester collected previously.
The Harvester page opens and displays a table of information about the current Harvesters.
A confirmation message opens.
The Harvester is deleted and is not listed in the Harvester table. The NFA console no longer collects data from the routers that are associated with the deleted Harvester. The data that was collected from those routers previously is not available in reports.
