Previous Topic: Change the Time Frame for a DashboardNext Topic: Sharing Data with Other Users
Build a Custom View for a Single Interface
You can create custom views that contain CA Network Flow Analysis data for a single interface. You can add these interface views to a custom dashboard in the Performance Center Console.
Several interface views are available in addition to the views that are displayed by default on the interface pages.
  1. Log in as a user with the required administrative role rights.
  2. Navigate to the dashboard page that will contain the new custom view.
  3. Click the More menu, and select Edit Dashboard (CA PC) or Edit Report (NPC).
    The page for editing the dashboard opens.
  4. Open the dialog for selecting the context:
    The dialog for selecting the context opens.
  5. Select Interface from the Context Type list (CA PC) or Type list (NPC).
    A table of interfaces opens, which shows the available interfaces or interfaces and routers (CA PC).
  6. Locate and select an interface.
  7. (CA PC) Click OK.
    You return to the Edit Dashboard Layout page.
  8. Expand the view category:
  9. Drag one or more of the interface views into the layout.
    A dashboard can contain a maximum of 25 views. If you include multiple copies of the same view type, you can edit each view on the custom dashboard to show content from a different interface.
  10. Click Save.
    The dashboard page refreshes.
