No Analysis reports are installed by default. A report folder named Analyses exists by default, which you cannot delete. You can store your saved Analysis reports in this folder or you can create other folders to organize your Analysis reports.
The Analysis Wizard opens and displays options for creating an analysis definition or modifying a copy of an existing analysis definition.
Define an entirely new Analysis report.
Select an existing report to copy and use as a basis for the new report.
If you select "Create a new analysis," the Select Interfaces page of the Analysis wizard opens.
Select one or more individual interfaces from the Interface Index.
Select one or more interface groups from the Interface Group Selection list.
The selected interfaces are added to the interface list.
The Specify Filters & Threshold page opens.
Select individual protocols from the Protocol Index.
Select protocol groups from the Protocol Group Index.
Select individual ToS values from the ToS Index.
Select ToS groups from the ToS Group Index.
Specify a host IP address and mask.
Identify the IP addresses and mask for each party in the conversation pair.
For each filter listed, use only the data of the listed type. For example, use data from the listed protocol group, but not from other protocol groups.
For each filter listed, do not use the data of the listed type. For example, do not use data from the listed protocol group, but do use data from other protocol groups.
For example, to report on overutilized interfaces you might specify a threshold to examine total traffic that goes above 70 percent utilization.
The Specify Schedule page opens.
Limits the reporting period to an amount of time, ending at the time the report runs. Enter the number of time units in the Last box. Select a unit of time from the list (days, weeks, months, or years).
You can set up a schedule for a Duration report or you can run the report on demand.
Select the calendar icons and click dates to specify the Start and End of the report period.
Select hour and time values from the lists. Hour values are expressed in 24-hour format.
A Start-and-End report runs on demand. You cannot set up a schedule for a Start-and-End report.
The options in the Recurrence section are available only if you select ‘duration’ as the reporting period type.
The Enter Name page opens.
Accept the default folder or select a different folder to contain the new report.
Give the new report a name that will appear in the Reports list.
(Optional) Add a description to help identify the report. For example, you may to use the description to identify scheduled reports and to indicate distinguishing features of Duration reports.
Additional information about managing Analysis reports is in the topic Manage Analysis Reports.
The Summary & Submit page opens.
Save the report definition and return to the Custom Reporting page.
Queue the report to run and return to the Custom Reporting page.
Return to previous pages in the wizard to redefine the report.
