Previous Topic: Growth ReportNext Topic: Views on the Capacity Planning Report Page
Capacity Planning reports show traffic trends, which are useful for planning. Future traffic is calculated by analyzing previous traffic. Capacity Planning reports project trends for rate, volume, and utilization for the following data on the selected interface:
You can specify several display and calculation options for the report:
  1. Display an interface report in either of the following ways:
  2. Select Capacity Planning as the report type at the top of the page.
  3. Select the report scope:
    The report page is updated.
  4. (Optional) Change the reporting time frame and calculation options by using the Trend Settings options.
  5. (Optional) Change the data presentation type and the data measurement type by using the Presentation options: Rate (default setting), Volume, or Utilization
    Each option displays views of data that is inbound (In) and outbound (Out) on the interface.
