Interface Reports › Interface Report Types › Top N ToS Report
Top N ToS Report
The Top N ToS report provides information about the Types of Service (ToS) markings of the packets that generate the most traffic for the selected interface. This topic describes how to display a Top N ToS report.
- Display an interface report in either of the following ways:
- Locate and click an interface on the Interfaces page.
- Click an interface link in an existing view--for example, on the Enterprise Overview page.
- Select ToS as the report type at the top of the page.
- Make sure the report scope is set to Top N ToS. The Top N ToS link should appear next to the report type setting.
The report page is updated to show ToS data in stacked trend charts. The report includes views for inbound, outbound, and total ToS data.
- (Optional) Change the type of data presentation and measurement by using the Presentation options.
- Stacked Trend Chart of Rate, Volume, or Utilization data (Default setting)
- Trend Chart of Rate, Volume, or Utilization data: Use the Show Top setting to specify the maximum number of conversations to include.
- Pie Chart
- Summary Table of Rate, Volume, or Utilization data
Each option displays data that is inbound and outbound on the selected interface.
- (Optional) Change the reporting period: Open the Timeframe dialog by clicking the timeframe link.
The reporting period is the most recent 24-hour period by default.
Display an Interface Report for a Single ToS
To drill down to more detailed, ToS-specific data for the selected interface, click a ToS link in a Top N ToS view. An overview report for the ToS value on that interface opens.
You can view the report in Overview or Details mode by selecting one of the following report types:
- Overview mode Mixed Chart or Mixed Trend chart: Rate, volume, or utilization data for the ToS on the selected interface
- Overview mode Pie Chart views:
- ToS Protocol Summary - In or Out: Data going in or out of the interface for the protocols that use the ToS
- ToS Hosts Summary - From or To: Data going from or to the hosts that use the ToS
- ToS Conversations Summary - Total: Data for all conversations that use the ToS (coming in and going out of the interface)
- Details mode: Charts of rate, volume, or utilization data in any combination of the following views, which are shown with or without baselines:
- (Displayed by Default) Last Hour, Last 2 Hours, Last 8 Hours, and Daily
- Weekly, Monthly, and Yearly
- Protocols mode Trend Chart or Summary Table: Rate, volume, or utilization data
- Protocols mode Stacked Trend Chart or Pie Chart views of data for the protocols that used the ToS: In (inbound on the interface), Out (outbound on the interface), or Total
- Hosts mode Trend Chart: Rate, volume, or utilization data for the number of top hosts you specify
- Hosts mode Summary Table: Table of rate, volume, or utilization data for hosts who used the ToS on the selected interface
- Hosts mode summary Pie Chart views of data for the hosts that used the ToS: From (data from the host), To (data to the host), or Total
- Conversations mode Trend Chart: Rate, volume, or utilization data for the number of top conversations you specify
- Conversations mode Summary Table: Table of rate, volume, or utilization data for conversations that used the ToS on the selected interface
- Conversations mode Pie Chart: Data for all conversations that used the ToS on the selected interface
To return to the summary view, click the link named for the currently selected ToS and click Select Top N Hosts.
Find ToS Views in the Performance Center Console
ToS data from CA Network Flow Analysis is displayed in the following Performance Center Console locations. (The built-in dashboards and report pages that are noted here show the views by default.)
- Stacked ToS Trend
- (CA PC) Interface Pages: CBQoS report page or a custom dashboard
- (NPC) Interface Pages: Interface QoS or custom tab views
- ToS Summary Pie
- (CA PC) Custom dashboard; Interface Pages: IP Performance tab
- (NPC) Interface Pages or custom tab views
- ToS Summary Table
Also See:
ToS Summary (Pie)
ToS Summary (Table)
Stacked ToS Trend
