Review the global settings that affect application mappings. Make any adjustments that are needed to customize application mapping behavior. The global settings that affect application mapping include the following options:
The Application Definitions page opens.
The Application Settings page opens.
For example, suppose that you create an application mapping rule that has port 655 as the destination port. You set the TCP Rebase Port value to 630. If port 655 is receiving native (non-mapped) traffic, the native traffic is redirected to port 630.
Note: The rebase port is used to avoid merging mapped traffic with other types of traffic. If application mapping rules are configured with unused destination ports, the rebase port is not used: Reports do not show traffic on the rebase port. If your reports show traffic on the rebase port, you may want to specify a new destination port for the mapped traffic. Examine the rebase port traffic to determine which rules are involved.
Your changes are saved. The Application Settings page remains open.
