To start, stop, or check the status of services, you can use the Windows Services window or the Linux Service Configuration window.
The CA Network Flow Analysis and CA Anomaly Detector services are described briefly in the following table. The Stand-Alone column shows which services reside on a two-tier stand-alone server. The other server columns show where the services reside in a two-tier or three-tier distributed deployment. The CA Anomaly Detector services run on the installation server for that program, which may be the stand-alone, NFA console, or separate CA Anomaly Detector server.
Service |
Stand-Alone |
Harvester |
Console |
DSA |
Anomaly Detector |
CA NFA Collection and Poller Webservices (Linux: nfa_collpollws) Provides web service interfaces for the NFA console to communicate with the Harvester and Poller (Stand-alone and Harvester servers). |
Yes |
Yes |
CA NFA Data Retention (Linux: nfa_dataretention) Manages trimming to enforce volume and date limits for retaining data files. 2-tier: 15-minute, 1-minute, and Flow Forensics data (Stand-alone/Harvester) 3-tier: 15-minute data on DSA servers; 1-minute and Flow Forensics data on Harvester servers |
Yes |
Yes |
Yes |
CA NFA DNS/SNMP Proxies (Linux: nfa_proxies) Handles SNMP and DNS requests from the Poller. Uses port 8081 by default. |
Yes |
Yes |
CA NFA DSALoader 3-tier: Processes 15-minute data (.rpr files) into .rpa15 files for storage on DSA servers. |
Yes |
CA NFA File Server (Linux: nfa_filewebservice) 2-tier: In a distributed deployment, hosts the web service on the Harvesters to handle file requests from the NFA console Pump service. 3-tier: Hosts the web service for requesting file transfers between the DSA and the NFA console servers. |
Yes |
Yes |
Yes |
CA NFA Harvester (Linux: nfa_harvester) Runs the Harvester/collector process. |
Yes |
Yes |
CA NFA Host Resolver Service Performs hostname lookup for any host that has anomalies detected by CA Anomaly Detector. |
Yes |
Yes |
CA NFA Hunter Tracker Service Starts and stops the AnomalyDetector process for CA Anomaly Detector. |
Yes |
Yes |
CA NFA Poller (Linux: nfa_poller) Initiates and handles SNMP requests to the devices that export flow to the product. |
Yes |
Yes |
CA NFA Pump 3-tier: Retrieves .rpr files from the NFA console. |
Yes |
CA NFA Reaper (Linux: nfa_reaper) Runs the Reaper process, which processes incoming files and writes out files for 1-minute, 15-minute, and some Enterprise Overview data. |
Yes |
Yes |
CA NFA RibSource Provides a static interface--a RIB or Report Information Base interface--to provide the NFA data that appears in Performance Center views. |
Yes |
Yes |
Yes |
CA Performance Center SSO Runs the Single Sign-On authentication software, so users can navigate between the NFA console and Performance Center without signing on again. |
Yes |
Yes |
NetQoS MySql Runs the standard MySQL instance using port 3308 and stores MySQL configuration data. |
Yes |
Yes |
Yes |
Yes |
Yes |
NetQoS NQMySql (Linux: nfa_mysqlCSE) Runs the Custom Storage Engines and provides an interface to run queries against the 1-minute, 15-minute, and Flow Forensics data. |
Yes |
Yes |
Yes |
NetQoS Reporter Manager Service Runs maintenance threads in the background to handle the interoperation of the components. |
Yes |
Yes |
NetQoS Reporter/Analyzer General Services Maintain log retention in the reporter/Logs directory and handles data retention for Enterprise Overview data. |
Yes |
Yes |
NetQoS Reporter/Analyzer Pump Service Tasks include: Collecting and processing Enterprise Overview data from Harvesters. 3-tier: Also collecting .rpr files from Harvesters and copying them to a staged folder for a DSA to retrieve. |
Yes |
Yes |
NetQoS Reporter/Analyzer Query Services Act as the interface for Custom reports and Analyses. |
Yes |
Yes |
NetQoS ReporterAnalyzer Report Service Executes Custom reports, Analyses, Flow Forensics, and Site to Site reports. |
Yes |
Yes |
NetQoS Reporter/Analyzer Watchdog Polls components for status information, in order to provide administrators with warnings. Also runs simple database integrity checks. |
Yes |
Yes |
