Post-Installation Tasks › Configure the Recycle Bin
Optionally, you can configure the Recycle Bin to remove deleted files from the server immediately. The default behavior is for the system to save copies of deleted files in the Recycle Bin.
Required/Optional
Servers to Configure
Recommended
All servers
- Log in as a user who has administrator privileges for CA Network Flow Analysis.
- Right-click the Recycle Bin icon on the desktop.
- Select Properties from the menu.
The Recycle Bin Properties dialog opens.
- Select Local Disk (C:) on the General tab.
- Select the option that is labeled "Don't move files to the Recycle Bin. Remove files immediately when deleted."
- Click Apply.
- Repeat these steps for each additional drive that you want to configure.
- Click OK.
