Previous Topic: Install the SoftwareNext Topic: Install a Distributed Deployment
Install the Components on a Stand-Alone Server
A stand-alone server is a single server that hosts the NFA console and the Harvester. Complete the steps in this topic to install all of the components on a single Windows server or virtual machine.
Follow these steps to complete the Harvester phase:
  1. Verify that the installation server is prepared as described in Prepare the Windows Servers.
  2. Log in as a user who has administrator privileges for CA Network Flow Analysis.
  3. Start the Harvester phase of the installation: Double-click the NFHarvesterSetup9.3.0.exe file.
  4. Verify that the appropriate language is selected, then click OK.
    The Welcome screen opens.
  5. Click Next.
    The CA NFA Harvester License Agreement screen opens.
  6. Review and accept the license agreement:
    1. Read the license agreement and scroll down.
    2. If you want to continue under the terms of the license agreement, click the option to accept it. This option is activated when you scroll to the bottom.
    3. Click Next.
      Prerequisite tests run to look for problems on the server. If a problem is found, an error message opens. A critical problem causes the program to exit. A Pre-requisite Check Warning message or other warning message opens for non-critical problems, which gives you the option to make corrections now or after the installation or upgrade is complete.
  7. Review the test results in the Pre-requisite Check Warning message, if it opens:
    1. Correct problems now or wait until the program finishes. For more information about the warnings, see the Troubleshooting section.
    2. Click OK to close the message.
  8. Verify or specify the installation directory:
    1. (Optional) Click Choose in the Choose Install Folder screen to change the installation location.
      The default location is C:\CA\NFA. We recommend that you install CA Network Flow Analysis components on a drive that is dedicated to CA Network Flow Analysis--not the operating system drive. The NFA console will be installed to the same directory that you choose for the Harvester.
    2. Click Next when the installation path setting is correct.
      The Pre-Installation Summary screen opens.
  9. Review the pre-installation information, then click Install.
    The Installing Harvester screen opens. When the installation is complete, the Install Complete screen opens and reports any errors that occurred.
  10. (Optional) If errors occurred during the installation, see the following log for details:
    <install_path>\Harvester_Install_<timestamp>.log (where <timestamp> is the time the log was created)
  11. Click Done in the Install Complete screen.
    The Harvester installation program closes.
Follow these steps to complete the NFA console phase:
  1. Start the NFA console installation software: Double-click the RAConsoleSetup9.3.0.exe file in Windows Explorer.
    The language selection screen opens.
  2. Verify that the appropriate language is selected, then click OK.
  3. Click Next in the Welcome screen.
    The NFA Console License Agreement screen opens.
  4. Review and accept the license agreements:
    1. Read the NFA console license agreement and scroll down.
    2. If you want to continue, click the option to accept the license agreement This option is activated when you scroll to the bottom.
    3. Click Next.
      The Third-Party License Agreement screen opens.
    4. Read the third-party license agreement and scroll down.
    5. If you want to continue, click the option to accept the third-party license agreement. This option is activated when you scroll to the bottom.
  5. Click Next.
    Prerequisite tests run. If an error message opens that requires attention, see Troubleshooting.
  6. Review the test results in the Pre-requisite Check Warning message, if it opens:
    1. Fix any noncritical problems now or wait until the program finishes.
      The Singlebox Confirmation message opens and asks you to confirm that you want a stand-alone deployment.
  7. Review the information and click OK.
  8. Review the pre-installation information, then click Install.
    The Installing NFA screen opens. When the NFA console installation is complete, the Install Complete screen opens.
    1. Select "Yes, restart my system."
    2. Click Done.
      Installation is complete.
Next: Complete the post-installation tasks.
