Previous Topic: Prerequisites for Flow Cloner InstallationNext Topic: Configure Flow Cloner Options
Install the Flow Cloner
Use the steps in this topic to install the Flow Cloner.
  1. Log in to the Windows-based Harvester installation server as a user with administrator privileges.
    The installation server must have the CA Network Flow Analysis 9.3.0 Harvester software installed.
  2. Locate the installation program file: <install_path>\setup\FlowClonerSetup9.3.0.exe.
  3. Start the installation program: For example, double-click the FlowClonerSetup9.3.0.exe file in Windows Explorer.
  4. Click Next in the Welcome screen that opens.
    The Pre-Installation Summary screen opens and shows the installation path and disk space requirements. The Flow Cloner will be installed in the same root installation directory that is used for the Harvester or stand-alone software.
  5. Click Install.
    The Install Complete screen opens when the installation is complete.
  6. Click Done.
    The installation program closes. An installation log file named FlowCloner_Install_<timestamp>.log is created in the root installation directory.
Next: Configure the Flow Cloner options.
