Previous Topic: Customize Predefined ViewsNext Topic: Zoom In to Narrow the Time Frame
Set a Custom Time Frame
You can select a different time frame for the data shown in the current dashboard or view page. You can select the day, the start time, and the end time using the time period selectors.
  1. Navigate to a dashboard or view page.
  2. Click the date links in the upper-left corner of the dashboard page to open the calendar panes.
  3. Select the beginning day and ending day of the new time period on the calendar panes.
  4. Click the hours or minutes links to specify the beginning and ending times of the new time period.
  5. Click Set.
    The custom time frame is applied to all of the views on the dashboard or page.
Change the View Settings
You can change several settings for a view. This topic describes how to open the dialog for editing view settings. The options that are available vary.
  1. Open the page that contains the view you want to modify.
  2. (Optional) Change the time frame.
  3. Open the dialog for editing the view settings:
  4. (Optional) Change any of the following options:
  5. Click Save (CA PC) or OK (NPC) to save your changes.
    The settings dialog closes. The view reflects your changes.
