Previous Topic: Add Products to Monitor (CA NetQoS Performance Center)Next Topic: Enable the Monitored Products (CA Performance Center)
Enable the Monitored Products' Collection Sources
After you add products for CA Anomaly Detector to monitor, enable the products so that monitoring can begin.
This task is described in the following topics:
When you add CA Network Flow Analysis as a monitored product, the Harvesters that are configured with the CA Network Flow Analysis instance are added automatically as possible data collection sources. You can enable as many or as few Harvesters as you need. Special considerations apply when you enable Harvesters, as described in Best Practices: Slow Harvester Rollout.
The product databases are the collection sources for the CA Application Delivery Analysis (SuperAgent), CA NetVoyant, and CA Unified Communications Monitor products.
