Post-Installation Tasks › Configure Firewalls
Configure Firewalls
Modify your firewall as needed to enable CA Anomaly Detector and the Harvesters to communicate. In addition, review your Access Control Lists (ACLs) and make any changes that are needed.
The following ports are used by default for communication:
- CA Anomaly Detector server to the Harvester ports:
- TCP 3307 (MySQL server)
- UDP 161 (Watchdog services)
- CA Anomaly Detector server to other servers that host data sources (NFA console, CA Application Delivery Analysis (SuperAgent), CA NetVoyant, and CA Unified Communications Monitor):
- CA Anomaly Detector server ports (outbound):
- UDP 514 (Syslog alerting)
- UDP 162 (SNMP alerting)
- Performance Center server to the CA Anomaly Detector server:
- TCP/HTTP 80, if http is used for communication
- TCP/HTTPS 443, if https is used for communication
- CA Performance Center to the CA Anomaly Detector server:
- TCP 8681, which CA PC uses to request data for the views
