Previous Topic: Configure Data Execution Prevention (DEP)Next Topic: Preparing Linux Servers
Prepare to Change the Performance Center Version
The NFA console or stand-alone server must be registered as a data source for a supported version of CA Performance Center (CA PC) or CA NetQoS Performance Center (NPC). If you plan to to switch between NPC and CA PC, prepare for the switch as described in this topic:
  1. Prepare for unregistering from your current Performance Center version as described below.
  2. Unregister from Performance Center
  3. Perform the CA Network Flow Analysis upgrade.
Important! We generally do not recommend unregistering. Many customizations are lost when you unregister and register again. Read this topic carefully to prepare for these events.
General Guidelines
Results of Unregistering from CA NetQoS Performance Center
If you unregister CA Network Flow Analysis from CA NetQoS Performance Center and register again with CA Performance Center, the following rules apply.
  1. Log in to the Console for CA NetQoS Performance Center as a user who is a member of the Administrators group.
  2. Review your records of the customizations in CA NetQoS Performance Center, such as:
    Remember that these elements may require checking, restructuring, or restoration.
  3. (Optional) Prepare for the effects of unregistering:
    Consider giving a unique name to each group so it is easy to restore the group hierarchy. For example, name each group in a way that indicates its relationship to other groups.
    To ensure that no groups are deleted, flatten the group hierarchy before you unregister.
  4. Open the Data Source List page: Click Admin, NetQoS Settings: Data Sources.
  5. Select the Reporter Analyzer or CA Network Flow Analysis data source.
  6. Click Delete.
