Previous Topic: Modify the Access Control ListsNext Topic: Configure Web Content Expiration
Disable User Account Control (UAC)
We recommend that you disable User Account Control (UAC) on any Windows stand-alone server or NFA console server. UAC is not fully supported for the current version of CA Network Flow Analysis. Enabling UAC on the stand-alone server or NFA console server can result in unexpected behavior.
Required/Optional
Servers to Configure
Recommended
Stand-alone, NFA console
  1. Log in as a user who has administrator privileges for CA Network Flow Analysis.
  2. Click Start, Control Panel, User Accounts.
    The User Accounts window opens.
  3. Click "Change User Account Control settings."
    The User Account Control Settings dialog opens.
  4. Move the slider bar to the bottom "Never notify" level, if it is not already at this level.
    UAC is set to be disabled for all local accounts on the server.
  5. Click OK.
    You return to the User Accounts tasks page.
  6. Close the window.
