For client systems that are used to log into the NFA console: We recommend Microsoft Internet Explorer version 8. Other browsers or browser versions may work with the NFA console, but have not been tested.
For installation systems: If you install a browser, install Microsoft Internet Explorer version 8.
Required/Optional |
Browser Support |
Servers to Configure |
Browser Required |
Internet Explorer 8 recommended |
Systems that are used to log into the NFA console |
Browser Optional |
Internet Explorer 8 required if a browser is installed |
Installation servers |
To set up CA Network Flow Analysis and work with data in the CA Performance Center Console, use Internet Explorer with Compatibility View turned off. You can use Internet Explorer in the NFA console with Compatibility View turned on or off.
If Internet Explorer Developer Tools are installed, you can use F12 to access Compatibility View options for the current browser session:
A new pane opens in the lower half of the window.
Notes:
Copyright © 2014 CA.
