Preparing Windows Servers › Install IIS, ASP, and COM+
Use the steps in this topic to install the following required components on a stand-alone server or NFA console server:
- IIS
- ASP
- IIS 6 Management Compatibility
- COM+ Network Access
Required/Optional
Servers to Configure
Required
Stand-alone, Console
- Log in as a user who has administrator privileges for CA Network Flow Analysis.
- Select Start, Administrative Tools, Server Manager.
The Server Manager window opens.
- Expand the Roles list in the Console tree on the left.
- Add the IIS role service:
- Click the Application Server link under Roles in the Console tree on the left.
The Application Server view opens in the right pane.
- Click the Add Role Services link in the Role Services section.
The Add Role Services wizard opens to the Select Role Services page.
- Select the Web Server (IIS) Support check box.
- Click Add Required Role Services in the confirmation message that opens.
The Web Server (IIS) Support option is highlighted on the Select Role Services page.
- Add the COM+ role service:
- Select the COM+ Network Access check box.
- Click Add Required Role Services in the confirmation message that opens, then click Next.
The Web Server (IIS) page of the Add Role Services wizard opens.
- Enable IIS 6 Management Compatibility:
- Click Next again.
A list of role services opens.
- Select the IIS 6 Management Compatibility check box in the Management Tools section.
- Click Next.
The Confirm Installation Selections page summarizes your actions and displays related messages.
- Install the IIS and COM+ role services and options you selected:
- Click Install.
The Results page opens when the installation or upgrade is complete.
- (Optional) Click ‘Print, e-mail, or save the installation/upgrade report, review the information,’ then close the page.
- Click Close.
The Results page closes.
- Add and install the ASP role service:
- Click the Web Server (IIS) link under Roles in the Console tree.
The Web Server (IIS) view opens in the right pane.
- Select the ASP check box under Application Development in the list and click Next.
The Confirm Installation Selections page summarizes your actions and related messages.
- Click Install.
- Click Close.
The Installation Results page closes.
- Exit from the Server Manager window.
Copyright © 2014 CA.
