You can export the current dashboard or Interface page as a PDF report attached to an email message. The Email feature lets you specify the email address of the recipient and the Subject line of the email message.
Sending reports as email attachments requires an administrator to specify an SMTP server. In CA Performance Center, your user account must also have the required role, 'Send Reports by Email.' For more information, see the Related Topics.
Specifies the email addresses where the report should be sent. Use the standard format:
<name>@<domain>
Note: Use commas or semicolons to separate multiple addresses. Or you can enter an email alias that includes multiple recipients.
Appears in the email Subject line; describes the emailed report.
Example: The dashboard title and any components whose data is included in the report.
(Optional) Is a message to accompany the emailed report.
Or select Send on a Schedule to create a schedule to send the email message on a regular basis. For more information, see Set Up a Recurring Email Schedule.
If the dashboard contains at least one multiview, a check box labeled 'Display maximum results for multiple-chart views' appears. Select this option if you want to include more charts from the multiview than can be displayed on the current "page" of results.
The server generates a PDF from the current dashboard and sends the report as an attachment to an email message.
Copyright © 2014 CA.
