Making Additional Customizations › Set Up Application Mapping › Import Application Mapping Rules
You can create or update application mapping rules by importing a .csv file that is formatted for the rule type. You can perform several types of application mapping rule imports:
Importing rules has the following effects and characteristics:
- After the import, the new or updated rules are shown in the Application Definitions page list.
- Reports show mapped traffic with labels that match the new rule names, as described in Set Up Application Mapping.
- Perform this type of import operation locally--you cannot perform the import remotely.
- You can work on the application mapping rules in a Microsoft Excel spreadsheet, then export the rules to .csv format.
- If you import the default NBAR2 rule set, each NBAR2 application is mapped to a separate port by default. The default port range is port 65001 and above.
Note: For information about import failures and potential error messages, see Mapping Rule Import Errors.
Copyright © 2014 CA.
