Previous Topic: VLAN Report GroupNext Topic: Work with Flow Forensics Reports
WAAS Segment Report Group
WAAS Segment Report
Displays a report that identifies the WAAS (Wide Area Application Services) segment number and pass-through reason. Having the pass-through reason helps you determine why flow is not optimized.
The report shows meaningful data if the reporting routers have WAAS configured and if Cisco Performance Agent monitors the WAAS traffic. Other traffic does not return any meaningful values except for the router IP address.
The Application column values show the NBAR2 application name followed by the application ID. The application name is included if it is defined by the standard (not custom) NBAR2 engine. Otherwise the Application value may consist of only the application ID.
The WAAS Segment Flow Forensics report has the following fields.
Report
Router Addr
Application
Client Address
Server Address
WAAS Segment
WAAS Passthrough Reason
WAAS Segment
Y
Y
Y
Y
Y
Y
The report table includes a row for each unique combination of the following values:
