Previous Topic: Service ManagementNext Topic: How to Back Up and Restore Data
Service Logs
The service logs are described in the following table. The initial part of each path is the CA Network Flow Analysis installation path, such as the default locations--C:\CA\NFA on a Windows server or /opt/CA/NFA on a Linux Harvester server. The table lists the service log file names and locations on Windows and Linux servers, along with any available configuration file to control the log level setting.
Service / Log Information
Stand-Alone
Harvester
Console
DSA
CA NFA Collection and Poller Webservices (Linux: nfa_collpollws)
Log: \Netflow\Logs\collpollws-wrapper.log
Yes
Yes
CA NFA Data Retention (Linux: nfa_dataretention)
Log: \Netflow\Logs\dataretention-wrapper.log
Yes
Yes
Yes
CA NFA DNS/SNMP Proxies (Linux: nfa_proxies)
Log: \Netflow\Logs\proxies-wrapper.log
Yes
Yes
Yes
(2-tier)
Yes
CA NFA DSALoader
Log: \Netflow\Logs\dsaLoaderErrors-<yyyy-mm-dd>.log
Yes
CA NFA File Server (Linux: nfa_filewebservice)
Log: \Netflow\Logs\fileserver-wrapper.log
Yes
Yes
Yes (3-tier)
CA NFA Harvester (Linux: nfa_harvester)
Log: \Netflow\Logs\harvester-wrapper.log
Yes
Yes
CA NFA Hunter Tracker Service
Log: Logs\ADLog<yyyy-mm-dd>
Yes
CA NFA Poller (Linux: nfa_poller)
Log: \Netflow\Logs\poller-wrapper.log
Yes
Yes
CA NFA Pump
Log: \Netflow\logs\pumpservice-wrapper.log
Yes
CA NFA Reaper (Linux: nfa_reaper)
Log: \Netflow\Logs\RealtimeReaperErrors<yyyy-mm-dd>.log
Yes
CA NFA RibSource
Log: \Reporter\RIB\NFA\webapps\NFARS\WEB-INF\logs\ application.log
Yes
Yes
CA Performance Center SSO
Logs: \Portal\SSO\logs\SSOService.log
\Portal\SSO\logs\wrapper.log
Yes
Yes
DNS Proxy Web Service
Log: \ProxyServices\Logs\DnsProxyWSLog<yyyy-mm-dd>.log
Log level setting (NFA console only): \ProxyServices\Web.config
<add key="LogLevel" value="6"/> Default: 4
Yes
Yes
NetQoS MySql51 (Linux: mysql51)
Log: \MySql51\data\<server_name>.err
Yes
Yes
Yes
Yes
NetQoS NQMySql51 (Linux: nfa_mysqlCSE)
Log: \Netflow\Logs\oursql_5.1_error.log
Yes
Yes
(2-tier)
Yes
NetQoS Reporter Manager Service
Log: \Reporter\Logs\Manager Service Log<yyyy-mm-dd>.log
Log level setting: \Reporter\ReporterAnalyzer.ManagerService\bin\ ReporterManagerService.exe.config
<setProperties Severity="6" /> Default: 4
Yes
Yes
NetQoS Reporter Manager Service thread logs in the \Reporter\Logs\ directory:
MigrationService: MigrationLog<yyyy-mm-dd>.log
PollerSyncService: CollectorSyncServiceLog<yyyy-mm-dd>.log
System Maintenance Service: ManagerService_MaintenanceLog<yyyy-mm-dd>.log
Yes
NetQoS Reporter/Analyzer General Services
Log: \Reporter\Logs\nqservErrors<yyyy-mm-dd>.log
Yes
Yes
NetQoS Reporter/Analyzer Pump Service
Log: \Reporter\Logs\PumpLog<yyyy-mm-dd>.log
Log level setting: \Reporter\NetQoS.ReporterAnalyzer.PumpService\bin\ NetQoS.ReporterAnalyzer.PumpService.exe.config
<setProperties Severity="6"/> Default value: 4
Yes
Yes
NetQoS Reporter/Analyzer Query Services (‘Reporting services’)
Log: \Reporter\Logs\nqreporterErrors<yyyy-mm-dd>.log
Automatic Groups task log: \Reporter\Logs\ManagerService_AutomaticGroupsLog <yyyy-mm-dd>.log
DNS task log: \Reporter\Logs\ManagerService_DnsLog<yyyy-mm-dd>.log
Maintenance tasks log: \Reporter\Logs\ManagerService_MaintenanceLog <yyyy-mm-dd>.log
Yes
Yes
NetQoS Reporter/Analyzer Report Service
Log (Flow Forensics log): \Reporter\Logs\ReportServiceLog<yyyy-mm-dd>.log
Log level setting: \Reporter\NetQoS.ReporterAnalyzer.ReportService\ bin\NetQoS.ReporterAnalyzer.ReportService.exe.config
<setProperties Severity="6" /> Default value: 4
To log each poll in addition to regular event logging:
<add key="VerboseLogging" value="True"/>
Yes
Yes
NetQoS Reporter/Analyzer Watchdog
Log: \Reporter\Logs\WatchdogLog<yyyy-mm-dd>.log
Log level setting: \Reporter\ NetQoS.ReporterAnalyzer.WatchdogService\bin\ WatchdogService.exe.config
Yes
Yes
Multiple processes
Log: \Reporter\Logs\ConsoleErrorsLog<yyyy-mm-dd>.log
Yes
ProductSyncWS Web Service Log:
\Reporter\Logs\ProductSyncWSLog<yyyy-mm-dd>.log
Yes
Yes
