After you create a shell ToS group, the next step is to add values to the ToS group.
The Domain setting is displayed only in a multi-domain environment.
By selecting a tenant-domain combination, you display any available domain-specific ToS labels, which help you identify the ToS values to use. The ToS group will not be restricted to the selected domain: ToS groups are available in all domains.
The ToS Index dialog opens. The ToS list displays the ToS index values and the ToS labels that have been defined. In a multi-domain environment, the ToS labels are displayed for the currently selected domain.
The ToS values are added to the ToS group.
An operator can select the ToS group from the ToS Group Index when defining an Analysis or Custom report.
Note: To define reports, the operator must have the necessary role and permission group settings.
Copyright © 2014 CA.
