Previous Topic: Add and Delete HarvestersNext Topic: Edit DSA IP Addresses
Edit Harvester Details
Edit the details for Harvesters on the Harvester page. You can edit the IP address, description, and tenant-domain setting.
  1. Select Administration from the NFA console menu.
  2. Select System: Harvester from the Administration page menu.
    The Harvester page opens and displays a table of information about known Harvesters.
  3. Click Edit on the Harvester row that you want to edit.
    The Edit Harvester dialog opens.
  4. (Optional) Change any of the following settings:
    IP Address
    Address of the Harvester
    Description
    (Optional) Additional information to help identify the Harvester
    Domain
    The tenant-domain association of the Harvester in a multi-domain deployment.
    Changing this setting affects the tenant-domain for any new routers that begin exporting flow data. Existing routers and interfaces retain their previous tenant-domain associations.
    The domain affects which operators and reports have access to the data from routers and interfaces.
    Changing the tenant of a router in CA Performance Center can affect which SNMP profiles are available for polling. This is not applicable to CA NetQoS Performance Center, which uses the same list of SNMP profiles for all routers.
    Default: Default Tenant\Default Domain
    If no custom IP domains have been created, the Harvester table includes only the IP Address and Description columns.
  5. Click Save.
    Your changes are saved immediately and appear in the Harvester table.
