Previous Topic: Set Up AnalysesNext Topic: View an Analysis Report
Create an Analysis Report
No Analysis reports are installed by default. A report folder named Analyses exists by default, which you cannot delete. You can store your saved Analysis reports in this folder or you can create other folders to organize your Analysis reports.
  1. Select Analysis from the NFA console menu if the Analysis page is not already open.
  2. Select Create New Report.
    The Analysis Wizard opens and displays options for creating an analysis definition or modifying a copy of an existing analysis definition.
  3. Select one of the options and click Next.
    If you select "Create a new analysis," the Select Interfaces page of the Analysis wizard opens.
  4. Select interfaces or interface groups for the report.
    1. Click one of the following options:
    1. Accept the default value or set the Inclusion value for each interface or interface group:
      • ‘Include’ sets the program to use report data from the interface or group.
      • ‘Exclude’ sets the program to eliminate data from the interface or group.
    2. Click Next.
      The Specify Filters & Threshold page opens.
  5. Specify the settings on the Specify Filters & Threshold page:
    1. (Optional) Specify filters for gathering or excluding report data, then set the Inclusion value for each filter to Include or Exclude:
      • Add Protocol Filter
        Select individual protocols from the Protocol Index.
      • Add Protocol Group Filter
        Select protocol groups from the Protocol Group Index.
      • Add ToS Filter
        Select individual ToS values from the ToS Index.
      • Add ToS Group Filter
        Select ToS groups from the ToS Group Index.
      • Add Host Filter
        Specify a host IP address and mask.
      • Add Conversation Filter
        Identify the IP addresses and mask for each party in the conversation pair.
    2. Accept the default value or set the Inclusion value for each filter you specified:
      • Include
        For each filter listed, use only the data of the listed type. For example, use data from the listed protocol group, but not from other protocol groups.
      • Exclude
        For each filter listed, do not use the data of the listed type. For example, do not use data from the listed protocol group, but do use data from other protocol groups.
    3. Set the Threshold Settings values to specify the threshold that is used for the Analysis report.
    4. Click Next.
    For example, to report on overutilized interfaces you might specify a threshold to examine total traffic that goes above 70 percent utilization.
  6. Click Next.
    The Specify Schedule page opens.
  7. Select the type of reporting period from the Period list on the Specify Schedule page:
  8. Accept the default Resolution setting on the Specify Schedule page or enter the number of time units in the Resolution box. Select a unit of time from the list (minutes, hours, days, weeks, months, or years).
  9. (Optional) Select a time filter from the list on the Specify Schedule page, if your Administrator has created a time filter that is appropriate for your report.
  10. (Optional) Select the Schedule check box on the Specify Schedule page and specify the following options:
    1. Schedule: Select the type from the Schedule list (Daily, Weekly, Monthly, Quarterly, Yearly).
      • Daily: Select the day or days of the week, time of day, and time zone for report generation.
      • Weekly: Select the day of the week, time of day, and time zone for report generation.
      • Monthly: Select either the date or the week in the month and day of the week. Select the time of day, and time zone for report generation.
      • Quarterly: Select a month that ends the first reporting quarter, time of day, and time zone.
      • Yearly: Select a month that ends the first reporting year, time of day, and time zone.
    2. (Optional) Email Results To: Enter the email addresses of all the report recipients in the format name@domain. Separate multiple addresses with a comma or semi-colon.
    The options in the Recurrence section are available only if you select ‘duration’ as the reporting period type.
  11. Click Next.
    The Enter Name page opens.
  12. Identify the report and its location and click Next:
    Additional information about managing Analysis reports is in the topic Manage Analysis Reports.
    The Summary & Submit page opens.
  13. Review the information in the Report Definition Summary.
