Custom Reports › Set Up Custom Reports › Specify Custom Report Filters › Delete Custom Report Filters
You can delete filters from Custom Reports to reflect the deletion of protocols, hosts, or TOS values from your network. Any filter you delete is no longer used to define the report data.
- Select Custom Reporting from the NFA console menu if the Custom Reporting page is not already open.
- Put the report in editable mode: Click the name of the report. If the report has been run previously, it runs again. In this case, click Edit in the Report Settings section at the top of the report page.
The Report Definition Summary page opens, which contains links to the Custom Report wizard pages.
- Click Host/Conversation Filters to open the Specify Filters & Rollup page of the Custom Report wizard.
- Select the check box next to each filter that you want to delete.
- Click the Remove Selected Filters icon at the top-left corner of the list.
- Click Save Changes.
Your changes are saved and you return to the Report Definition Summary.
- (Optional) Return to the report list by clicking one of these buttons:
- Return to Listing: Return to the Custom Reporting page without queuing the report to run.
- Queue Report: Queue the report to run and return to the Custom Reporting page.
Copyright © 2014 CA.
