Previous Topic: Create a Custom ReportNext Topic: Customize Which Interfaces Are in Custom Reports
Review Settings for Custom Reports
You can review the Report Definition Summary of a Custom Report to ensure that the report definitions are appropriate. From the Report Definition Summary page, you can access the Custom Report Wizard pages and can modify the report.
  1. Click the name of the report you want to modify in the Reports list on the main Custom Reporting page.
    Note: Select a report that is not currently in execution--a report that does not have the status Running.
  2. Display the Report Definition Summary page of the Custom Report wizard, if it is not already open. The steps for displaying the Report Definition Summary are dependent on the status of the report you select:
  3. Review the current report settings and click the name of the section you want to modify.
    For example, click Interface Filters, Protocol Filters, or ToS Filters to add new filters or change existing filter settings.
  4. The associated page opens, giving you access to the options that you can change.
    Also See: Set Up Custom Reports
    Review report settings on the Report Definition Summary page.
  5. When the changes are complete, click Queue Report to regenerate the report with the new settings.
    The Reports list opens and the modified report shows a status of Queued. When the report has been regenerated and is ready to be viewed, the status displays as Complete.
    When you modify a scheduled report, it is queued to be generated at the next scheduled runtime.
