When you define a Custom Report, you must specify the reporting time period and the resolution of the reporting data. You can define a specific, nonrecurring time period (for a start-and-end report) or you can choose a timespan that ends at the report runtime (for a duration report). You also have the option to set a duration report to regenerate on a recurring schedule and to have the automated reports sent out by email.
Copyright © 2014 CA.
