Custom Reports › Report Types and Usage
Custom Reports can show a variety of data, including the following types of information:
- Interface: View the total volume of traffic that is generated across particular interfaces.
- Protocol: Discover which applications are used by various business groups.
- ToS: View the distribution of applications by type of service (ToS).
- Host: View the activity or usage levels for applications on a server.
- Conversation: View the top conversations across interfaces or for a particular protocol.
Report on Network Utilization
Create a custom interface report to select the included interfaces so that you can report on network traffic by:
- Location, such as global, regional, country, state, and individual offices
- Business unit or department, such as Accounting, Marketing, and Sales
- Specific interface groups, such as EMEA, WAN, ATM interfaces, and Ethernet interfaces
Report on Application Distribution
Create a custom protocol report to focus on the applications and protocols in use in your organization. You can generate protocol distribution reports to:
- Show the applications that are used in each region.
- Understand which applications are used the most frequently.
- Determine whether any applications can be removed from the network or de‑prioritized.
- Verify that rogue applications are not active on the network.
Report on ToS Distribution
Create a custom ToS report to identify the ToS categories for the most heavily utilized applications in your environment. You can generate ToS reports to:
- Understand which ToS is most widely used in your environment.
- Show the ToS categories in use in each regional location.
Report on Server Activity
Create a custom host report to identify the amount of traffic sent to and from particular servers in your organization. You can generate host reports to:
- Verify that application servers are utilized properly.
- Determine whether a server is vulnerable to any security risks.
- Determine whether a specific data center can handle additional servers.
Copyright © 2014 CA.
