Previous Topic: Open the Flow Forensics PageNext Topic: View a Flow Forensics Report
Create a Flow Forensics Report
Complete the following steps to create a Flow Forensics report.
  1. Select Flow Forensics from the NFA console menu if the Flow Forensics page is not already open.
  2. Click Create New Report.
    The Report Settings page opens and displays options for the default report type, Conversation Sessions.
  3. (Optional) Change the report type:
    Select a report type in the Report Types dialog.
    Also See: Flow Forensics Report Types
  4. (Optional) Identify the report and set the folder for saving it by entering values in the following fields:
  5. (Optional) Change the filters that are used in the report definition:
    Example: To exclude the FTP protocol, complete the following steps:
    1. Select RA: Protocol Filter.
    2. Select NotEqual.
    3. Click Protocol Index.
    4. Select the ftp protocol.
    The following list describes the available filters.
    Note: Certain filters may not be available for all reports.
  6. (Optional) Change the timespan for collecting report data: Select Start Date and End Date values.
    Set the timespan by using the Start Date and End Date options.
  7. Run or save the report:
