Previous Topic: Open Interface ReportsNext Topic: Open an Interface Report: Router Tab
Use the Interface Index
When you log in to the NFA console, the Interfaces page opens and shows the Interface Index. You can use the Interface Index to select an interface and view reports for it. You can search for an interface on the Router or Group tab.
Note: The Group tab appears only if the product is registered as a data source for Performance Center. If the product is not registered, the Interface tab appears in place of the Group tab.
