A summary table is a good presentation choice when you want Protocol or ToS summary data that can be easily sorted and saved to CSV format for use in a spreadsheet program. Summary tables are available for the following Top N report types on Interface pages: Protocols, ToS, Hosts, Conversations, and AS Numbers.
In the following example, the Protocol Summary Table lists protocols from the highest to lowest flow volume. You can change the sort order of the list by clicking a column name. Click again to change the order from ascending to descending. The sort column is marked with an arrow.
Copyright © 2014 CA.
