Introduction › Introduction to Performance Center
CA Network Flow Analysis is designed to be integrated as a data source for either CA Performance Center or CA NetQoS Performance Center--whichever program your enterprise uses. The Performance Center Console displays report data from CA Network Flow Analysis and any other programs that are integrated as data sources.
When your administrator adds CA Network Flow Analysis as a data source for Performance Center, several changes occur:
- The NFA console banner contains a link the Performance Center Console (either CA PC or NPC).
- If your user account enables it, you can see CA Network Flow Analysis views in customizable dashboards and context pages in the Performance Center Console.
- Properly credentialed users also can drill in to details in the NFA console from views in Performance Center.
Notes:
- This guide uses the term Performance Center to refer to CA Performance Center and CA NetQoS Performance Center collectively. Program-specific page names or functions may be identified by the full program name or acronym, which is CA PC for CA Performance Center and NPC for CA NetQoS Performance Center.
- To learn more about Performance Center views and customization options, see the online help for Performance Center.
Copyright © 2014 CA.
