Previous Topic: Work with Reserved SeatingNext Topic: Edit Reserved Seating Rules
Create Reserved Seating Rules
Create Reserved Seating rules to help ensure that reports include the port and protocol combinations that interest you, regardless of traffic volume or rates.
  1. Open the Application Definitions page:
    1. Select Administration from the NFA console menu.
    2. Select Application Definitions in the Administration menu.
      The Application Definitions page opens.
  2. Select Reserved Seating from the Rules list.
    The Application Definitions page switches to Reserved Seating mode and displays a list of the current Reserved Seating rules.
  3. Click Add Rule.
    The Add Reserved Seating dialog opens.
  4. Specify ports as follows:
  5. Click Save.
    If you entered a valid port and protocol combination and you have not yet reached the maximum number of rules, the dialog closes. The new rule appears in the list of Reserved Seating rules.
  6. Repeat this process for each Reserved Seating rule you want to add.
    You can specify a maximum of 50 Reserved Seating rules.
