Previous Topic: Create Time FiltersNext Topic: Set Up Application Mapping
Create Reporting Periods
Create reporting periods to get the best results from reports. For example, suppose that your users typically analyze network traffic that occurs over two weeks. To make it easier to display interface data over this timespan, you create a two-week reporting period.
Custom reporting periods are available as Time Period options when a user clicks the time period setting in a drilldown interface report of any of the following types: Overview, Protocols, ToS, Hosts, Conversations, Flows, Utilization, and AS Numbers. For more information about these report types, see the CA Network Flow Analysis User Guide.
  1. Select Administration from the NFA console menu.
  2. Select Reporting Periods under the Administration: Reporting label in the Administration menu.
    The Reporting Periods Configuration page opens and displays a list of the current reporting periods, including the built-in and customized reporting periods.
  3. Click Add.
    Fields and options for adding a reporting period are displayed.
  4. Specify the following values:
  5. Save the reporting period by clicking one of the following buttons:
Note: To delete a reporting period, select it from the list, click Delete, then confirm the deletion when prompted. To edit a reporting period, select it from the list, change any of the options that are displayed, then click Submit.
