Previous Topic: Work with TrapsNext Topic: Configure Trap Destinations
Create Traps
  1. Display the Add a Trap Configuration page:
    1. Select Administration from the NFA console menu.
    2. Select Alerts from the Administration page menu.
      The Trap Configuration page opens and displays a list of the current traps.
    3. Click Add.
      The Add a Trap Definition page opens.
  2. Define the trap description and the interfaces that the trap monitors:
  3. (Optional) Create a Utilization-based trap by providing the following information:
  4. (Optional) Create a Rate-based trap by providing the following information:
    For example, suppose that you create a Rate-based trap and establish thresholds for both the inbound and outbound traffic. The trap is triggered when the threshold is met during the defined period.
  5. (Optional) Create a Volume-based trap by providing the following information:
  6. (Optional) Create a Flow-based trap by providing the following information:
  7. Click Submit when the selections are complete.
    The trap is deployed.
    Note: Traps are sent to the destination that is defined in the application settings.
To delete a trap definition, click the trap description in the Trap Configuration page trap list. Click the Delete button that appears in Edit mode. Verify the deletion when prompted.
To edit a trap definition, click the trap description in the Trap Configuration page trap list. Make updates in the Trap Configuration page in Edit mode. Click Submit. The trap is updated.
